But i was a bit inquisitive when i was on the server n asked Scar Mostly all the issues related to this thng..!
I Hope u Appreciate the wrk n This helps a bit... !
Personal Knighthood War
This is a function to allow 2 knighthoods
to officially rage war against each other.
Certain amount of Woonz is required to declare war.
Once war is declared,players gain points by
killing the opposing Knighthood members and monsters
over the War duration.
U can Check the points of urself and the opponents
by pressing 'F' key.
U can also check the opponent kh names.
How to go about the Procedure :
Press 'U' key..
Put the name of the Knighthood and u can declare war..
So once the opponent leader excepts
the war begins
NOTE : The Kh - leader should be in the same map to accept or deny the request of start/end of war.
If u are in an Allaince , ur entire Alliance is
pulled into the war against the opponent Knighthood and Alliance
How are points Distributed :
Kill the opponent Knighthood/Allaince player : 100 points
Episode 1 Maps
Niflgar Creeps : 1 points
S3/S4 Creeps : 27 points
All normal bosses : 2 points
Statue : 3 points
Red : 4 points
Episode 2 Maps
Syvave Creeps : 1 points
Tao Creeps : 2 points
Forest / P2 /Den Creeps : 3 points
Boss : 3 points
T Series Maps
Creeps : 3 points
Boss : 4 Points
Episode 3 Maps : 27 per Creep.. Means killing Irakadex5 gives 27X5..
Also , Both khs can request for Surrender And Termination Of war By Pressing 'F'..
And Most Importantly , The Loosing Knighthood Gets DISBANDED..!
Cheers,
Maximus
