mage lvl 70
raghavsey
mage lvl 70
Post by raghavsey »
i have a mage lvl 70,
i want it to be elemental and hence
i was originally adding stats like
4 Int
2 Dex
but since lvling is so fast and so many skill points i lost the track . . ..
so now i dont know if my stats are right or not
so what should i do ?
continue adding in the same manner, . . ..
or can somebody tell me what should be my stats for an elemental mage of a lvl 70 mage
also which G should i focus on buying ?
g7 or g8 ?
since lvling is so fast i barely wear a G for more than 10 mins . . . ..
and should i get them from npc or as drops ? . .. .
IGN : Lemik
IGC : Mage
http://www.dafosfiles.co.nr" onclick="window.open(this.href);return false;
bharatb
Re: mage lvl 70
Post by bharatb »
go nevia canyon for easy drops
ign:Merc
igt:quanato
Rabellu
Foman
Foman
Re: mage lvl 70
Post by Rabellu »
1. Adding the points like 4 nd 2 or 3-3 or 5-1 etc is not the deciding factor for being elemental or non elemental. This idea is good for low exp nd no rb servers where you don't get enuf stat points to wear any set of your choice.
It is a3mania - a high exp and rb server. After 4-5 rbs you can even use any g10 set at lvl 1. So add the points according to your attack, defence, hp nd mp needs. Being ele or non ele depend on which set you choose. Get ele set for ele mage nd non ele set for non ele mage. Thats it.
Now talking about the grade of set. Dn't buy ny set frm npc. Better buy from some player or go to nc or other map where g7 nd g8 items drop rate is good. Try to get a g8 set asap nd then make g9 set soon. And after that keep working for g10 set. Because g10 set is must for high rb chars as better set== better opts == rocking char.
For your g9 nd g10 set i will suggest you to get ele mage pants nd rest set of non ele mage.
I want my status to be Rabellu not this KnowledgeBase :(
raghavsey
Re: mage lvl 70
Post by raghavsey »
hey thanks have got my full g8
byrakuel set
i will start saving for g9 then ;)
IGN : Lemik
IGC : Mage
rockstar8
Reneias
Reneias
Re: mage lvl 70
Post by rockstar8 »
any mage shud focus on defence and blood wid primary concern...cos thats what they lack...
sb gives pretty neat dmg even wid screwed up int...
1st the blood then the defence then the attack...my way to go!
Pawnage is my middle name
Pawned will be urs
Face me in the game
And DEATH WILL BE URS!!
