Error Installing Client.....!
D71
Post by D71 » Fri Sep 09, 2016 10:25 am
Dear GM's
Please look into matter that when i m trying to install the game the following error occurs.
I already have latest .Net Framework as i m using Windows 10.
Please help me for the same.
Waiting for your eager response.
Trollface
Re: Error Installing Client.....!
Post by Trollface » Fri Sep 09, 2016 10:56 am
Hi Since you have Windows 10 which has dot net framework 4.5 preinstalled but the game launcher needs Dot net framework 3.5 . Here is a link to download and install Dot net framework 3.5 from Microsoft official website:
https://www.microsoft.com/en-us/downloa ... aspx?id=21
Install it and check. Hope it helps! Thanks...
D71
Post by D71 » Fri Sep 09, 2016 2:19 pm
Trollface wrote:Hi Since you have Windows 10 which has dot net framework 4.5 preinstalled but the game launcher needs Dot net framework 3.5 . Here is a link to download and install Dot net framework 3.5 from Microsoft official website:
Already tried the same..... =((
Trollface
Post by Trollface » Sat Sep 10, 2016 12:11 pm
Ohh! Actually once I faced similar issue and I downloaded Dot Net framework 2.0 and installed it and it worked may be try just installing dot net framework 2.0
D71
Post by D71 » Sat Sep 10, 2016 6:01 pm
Still same problem
forever
Dark Saint
Dark Saint
Post by forever » Sat Sep 10, 2016 6:37 pm
Hey there,
Make sure you run Troubleshooting to check if there is any problem due to windows update. After windows 10 feature update 1607, many players are reporting problems regarding sandboxie and all. I feel your issue must be due to updating to v1607. Try the troubleshooting feature by typing in the search box and running it. I hope it solves your issue. If not, make sure you drop a question to the Microsoft community as well they may help you in getting things right. :)
