There is an in-game shout of server , i.e use of Hack/ Bot will lead to permanent Ban .
It is understandable Auto Potter is now unusable. But what about dual issue , stats adding issue .
Is Sandboxie is allowed to Dual ???
Is Auto Clicker is allowed for adding stats after Rebirth ??
Is Auto Party software allowed now ?
If Game Masters clarify it it will be a great help .
Require Clarification From Game Masters
- Es Higel
Re: Require Clarification From Game Masters
Andhakanun ? Are you really andha by IQ also ?
Sandboxie is a bot ? And does anyone need to tell you that auto clicker and auto party software’s are bots?
Instead of begging characters from people and sending messages of suicide on whatsapp, use the little brain that god has given you. Stats adding and dualing aren’t “issues”, they are voluntary. Anything that does the repetitions for you is a bot. Indeed, common sense isn’t so common. And this lower than room temperature IQ noob wants to get into IIM B, trust me, even the IQ level of a janitor in IIM B shall be higher than you.
- Es Higel
Blackmagic aka Barking Bot Spotted Do You want me to make your real name official so that people can know the mentally challenged person behind Fake Id. Instead of poking nose everywhere you should focus on ur personal issues which u are suffering from since yearsBlackmagic wrote: ↑Fri Nov 15, 2019 2:15 am Andhakanun ? Are you really andha by IQ also ?
- Es Higel
Sir , can you please clarify above doubts . Thanksandhakanun wrote: ↑Thu Nov 14, 2019 11:53 pm There is an in-game shout of server , i.e use of Hack/ Bot will lead to permanent Ban .
Usage of any software that affects the functionality of the client and gives you an unfair advantage is not allowed. You can dual multiple clients as long as your are not directly modifying the client.
- Es Higel
Thanks sir for your reply , but what about you giving any dualing technique so that we follow the same and avoiding the risk of client modification.
The client is not designed to run more than 1 instance on a single PC due to technical limitations. You are on your own.
- Triggered
Regarding the recent post about "Player Conduct Rules", will the bans be imposed only for abuses made via Public shouts or does it include General chats, Personal Messages as well?
Maleficient
Alfaqforever
Crazyarcher
Alfaqforever
Crazyarcher
Ideally, it should be based on abuse made in any form( general, public, 5k)
"Only I Can Live Forever!!!"
