Respected Sir,
I downloaded the Your-Freedom & Free-Cap software ...
Installed it like u said in forums ... double checked the settings .. but still it does not connect to the server .
It shows the error 'connection to the server faled, please try again'
Wat shu i do now plz help .
Thank You.
Your-Freedom & Free-cap Software
Re: Your-Freedom & Free-cap Software
Did you start the Connection in Your-Freedom? And did you check the Settings in FreeCap?
thunderandy
Kindly see the pics tat i took of errors
There is some problem with Your-Freedom that you are using. Try to select another server and check if it connects.
You need to open the A3Client.exe file directly from FreeCap. The Updater won't work.
