cant connect plz read
DaRkMaRe
Post by DaRkMaRe »
CharName: Input Your
Is it an Issue or a Question to GM?: Issue
Have you raised a support ticket at the main website?: No
Issue or Question Type: Account Related Issue or Query
Description and Message
see iv got a similar problem as oder users previosuly...i v gone thru the threads.....all d users had d prob of deir anti virus.....n aftr dey uninstalled > it worked.....
but the prob wid me is...i v uninstalled my avg n den reinstalled d game...but stil im facing dat same problem...dat wen u click connect nuthing happens...n if i try bypass launcher....n click on connect it says cannot find A3client.exe tho i hav it in my folder......n wen i click d a3client.exe in my folder it says 'u dont hav appropriate permissions to access this item'...man i v really been trying a lot...
plz help me out.
Forum Robot
Automated
Automated
Post by Forum Robot »
Thank you for posting your request. Please wait for GMs to look into this matter. They will reply to you as soon as possible.
This is an automated reply
Please also make sure that you have logged a support request in the A3 Mania main website for faster resolutions. Also please read the announcements section for regular updates regarding server maintenance and updates.
Click here to Know how to log a support request in A3 Mania Website.
Thanks,
roshanpatil
Cullijpayhern
Cullijpayhern
Re: cant connect plz read
Post by roshanpatil »
Bro Just Uninstall Ur Antivirus
Or
Press Start> Then Run > Then Type "msconfig" in that
and Disable all Startup items
Or Last Opt is Format PC and Try :)
Mage : Christiana
Numenor
Site Administrator
Site Administrator
Post by Numenor »
No need to format. It si basically and OS setting or an antivirus setting. It might have removed the a3client.exe files from the zip archive as well as the folder. As you have uninstalled AVG, you should redownload only the "PATCH" 5.12 version and then use the a3client.exe file in it. It should work.
DONT PISS ME OFF. I get very mean and rude.
If its saying that you don't have Permission, then it means that your Antivirus is locking the file in order to prevent any other application or the user to access it due to the Virus detection in it.
Add an Exception and apply the Patch again. It should be fine.
sunny_a3mania
Post by sunny_a3mania »
Dude i guess you are not using the Administrator account on your computer. Login the admin account make the changes in anti-virus(Add a3client.exe to exception list or disable anti-virus) and then try starting the game.
I hope this works :)
Evilinside
Rb12 165
DarkKnights
Temoz
[GM]Warrior
Site Administrator
Site Administrator
Post by [GM]Warrior »
AVG has this known issue. I have got the same problem. it always deletes/vaults the a3client.exe. I have to go manually to the virus vault and restore the a3client.exe
Post by maximus »
Warrior...ur Avatar is Kewl.... :D :-bd !!
\m/ \m/
vicchuansel
Post by vicchuansel »
He has solved the issue actually..
He can now play from his PC..
regards...
Ansel...
Click the eggs , raise the chicks ^.^
Soloist RB 12 165
Use the Search Option before Posting. You can come across a lot of topics related to the same issue.
