FAILED TO CHANGE DISPLAY SETTINGS :-( HELP
ravensnowbird
Post by ravensnowbird »
Hey guys can anyone help me out with this problem??? when i click connect im getting this message "A3 ERROR - FAILED TO CHANGE DISPLAY SETTINGS"
Plz suggest me some thing.. TY.
ravensnowbird
Re: FAILED TO CHANGE DISPLAY SETTINGS :-( HELP
Is there anyone for technical support or not here????
Sabertooth
Post by Sabertooth »
Download the 510 patch manually and install it.. Do it again even if you have already done it..
http://www.a3mania.com/client/A3ManiaPatch_510.rar
ravensnowbird
Sad luck dude... not working.. any more suggestions???
This is my System configuration may be it'll of any help :
Intel Core 2 duo CPU E7200 @ 2.53 Ghz,2.53 Ghz
2 GB RAM
Intel PR31 original series
Intel(R) G33/G31 Express Chipset Family Graphics Adapter
Try to keep your Resolution settings in 800 X 600 Resolution. In the Game settings, try to set the graphics settings to normal and run the game.
ravensnowbird
I've tried everything dude.. still its not working.. and im using Kaspersky Anti Virus. will that cause any problem?
Bauer
Arr Khallhiash
Arr Khallhiash
Post by Bauer »
u could try to disable ur anti virus and try to see if the game can launch.. if it can then you've found your problem.
otherwise you could try re-installing the entire thing and keeping default settings.
IGN: Bauer
IGC: Warrior
IGT: Temoz
IGKH: Genocide
Demented
Cynick
Cynick
Post by Demented »
Well umm..I can't confirm this but, some of my friends have had problems playing in Vista. Try and run it in XP compatibility mode..
IGN : HellArcher
IGC : Archer (duh)
ravensnowbird
We'll i exited the anti-virus. put my default desktop settings and 800x600(16bit) and 800x600(32bit). both show the same result. And i am using Windows Xp sp3. i know it sounds cranky but most of you who like to solve problems like this can help me out.
ravensnowbird
Im using a samsung 17" lcd wide monitor .so i've got these options .
800x600
1280x600
1280x720
( 16 bit and 32 bit )
So is there anyone whoz using a samsung 17" LCD monitor ??? Or any LCD MONIITOR ??? i think you can solve my problem.. plz reply
