Ring / Necklace
Bauer
- Arr Khallhiash
Ring / Necklace
Whats the ideal ring and necklace a spear warrior should aim to get?
IGN: Bauer
IGC: Warrior
IGT: Temoz
IGKH: Genocide
Rabellu
- Foman
Re: Ring / Necklace
For ny class Redyan's necklace is best among necklace nd Redyan's ring nd larrtek ring r best among ring. Nd this choice of ring depends on u
Properties of larrtek ring
1. Defence 30
2. Ele 16,16,16
3.Decrease MP consumption by 50%
properties of redyan's ring
1. Def 100
2. Ele 45,45,45
3. Dec HP/MP urage by 30% and dec in fatigue by 50%
properties of redyan's necklace
1. Attk 100
2. Ele 45,45,45
3. Dec HP/MP usage by 50%
4. Dec in fatigue by 50%
5. Normal monster kill at set ratio.
6. Prevention of item loss on death(murdrers exempted)
Now by looking at the properties redyan's ring is better than larrtek ring for elemental defence. Nd if you use redyan's ring nd necklace then ur decrease in fatigue becomes 100% that is u will never get exhausted. Moreover elemental defence nd attack are very imp at aura stages for pvp.
But if u use redyan's necklace nd larrtek ring then ur decrease in MP becomes 100% that is u can cast skills even if u have 0 MP so u can take out points frm MP nd use for other purposes. But warriors dnt need hell lot of MP as they r master of melee. This combi is good for mages who r totally dependent on MP.
1. Defence 30
2. Ele 16,16,16
1. Def 100
2. Ele 45,45,45
1. Attk 100
2. Ele 45,45,45
I want my status to be Rabellu not this KnowledgeBase
Rabellu
- Foman
Re: Ring / Necklace
I just tried to elaborate the reply of scar. Hope ur all doubts get cleared.
Btw it seems u r preparing to get the best stuffs for ur char. But i must tell u that u will still not be able to pk an hk even if he have a set half good as urs because of huge hp bars nd heal.
Bauer
- Arr Khallhiash
Re: Ring / Necklace
Thanks for the info... Much appreciated..
IGN: Bauer
IGC: Warrior
IGT: Temoz
IGKH: Genocide
xboxer
laxman
Re: Ring / Necklace
now that the hp bars aint huge... warriors pawn due to their epi5 skills..
but a hk with good gameplay can still win
Rabellu
- Foman
Re: Ring / Necklace
@laxman
thanks for the info. Wasn't knowing that hp bars r not huge nymore. But can nyone please tell me reason for it?
Is it that there is limit on max hp bar if yes then wats the limit? Nd if ny other reason then pls tell that.
Rabellu
- Foman
Re: Ring / Necklace
@laxman
Bauer
- Arr Khallhiash
Re: Ring / Necklace
when u rb, your hp goes back to lvl 1 hp limit.
IGN: Bauer
IGC: Warrior
IGT: Temoz
IGKH: Genocide
Rabellu
- Foman
Re: Ring / Necklace
Arr that i know that hp bar become as lvl 1 char when we rb. But that doesn't mean one can't have huge hp bars. Ppl can still have very big hp bars if there is no restriction on max hp bar limit.
A 10rb 165 lvl hk will be unbeatable by ny 165 lvler.
At 10rb you get 3000points nd 984 points from the level ups. So total pts at 10rb 165 level become 3984.
Now till 165 level hk hp bar become 4480(1980 frm lvl up + 2500 frm 5 aura levels).
At aura stages ur points in attack doesnot play important role rather elemental attk is important. So hk with 500pts in attk will do almost same damage for pk even if he have 5000pts.
So if hk add 500pts to attk so as he can change weapons then he is left with 3484pts.
Now defence of 1.5k is enuf nd this can be achieved by adding around 1500 pts in defence because we get defence frm set nd shue also.
So points left are 3484-1500= 1984
now add all 1984 pts in hp bar then the bar becomes 4480+(1984*4)=12416
now who will beat hk with this much bar in 1 on 1 ?
laxman
Re: Ring / Necklace
hmmm...
hks can be beaten...
A aura5 warrior with epi5skills+lvl15 g9 uni weapon+maxed g9/g10set still has a chance
I donno much about their skills... but there is some skill which doesnt allow to remove their buffs n
there is some cruise thingy which increases their attack speed n all the 3 cruises combined.
he can do imba damage on the hk..
something like 3k+ on his crits
Since the melee speed is imba with through the proxy.. 4 continous crits will see the hk on floor
If the hk uses dex then there is no chance... but with a non-dex.. there is a chance
N common... at present only Knight has gameplay in the server...
There is a aura5 hk but he has veryyy sad gameplay...
N Knight is aura2 n Cybertooth is aura5
if knight uses dex he can still beat him i guess.. but i donno abt the 0s
anyways... epi5 skills are imba for warriors... it makes them very very very strong
Rabellu
- Foman
Re: Ring / Necklace
@laxman
arr bhai going for war at aura 5 without dex will be one of most noobish thing one can do. In my above post all i said is for hk with g9 dex nd good gameplay. Warrior do have got a skill which wnt let u use buffs on them but that skill dnt have huge duration. Nd that high cruize give them 2.5 times hit rate but wat can they do to hk with imba hp bar nd dex on. No critic nd hk have to just hit nd heal hit nd heal nd at last warrior have to tp or die.
Btw why we r debating lolz u r hk so keep rocking nd i wnt be coming back to play.
Rabellu
- Foman
Re: Ring / Necklace
K. Enjoy the lyf.
I would have continued on this server but m fed up of playing hk nd hk nd if i play i make only best class char no matter how hard it is to lvl up because good things need sm patience
warriors are supposed to be best in epi 5 but no restriction of max hp bar favour hk.
Nd second reason for leaving is in my sigy.
