Bid Starting cost: 3 bill
Minimum and Maximum Bid increment: 250 mill.
The first person to bid has to start from 3.25 Bill
Second : 3.5 Bill
Third : 3.75 Bill
vice versa ....
You cannot jump Bids. You have to follow the min and max Bid increment. Read the rules below carefully.
Common Rules for this Auction
1. Unlimited Bids Allowed [Bid Count].
2. The Bid will start from the minimum bid amount mentioned in the post.
3. You will have to mention your ingame charname along with the Bid. Mention you Bid Count too. Eg. My Bid # 2 : 200 mill
4. The auction for Item will close on 15th September regardless of the start date of the auction.
5. The auction winner will be given the item ingame by the GMs AFTER taking the bid amount Wz.
6. If the current winner fails to pay the Bid amount and take the item; then he will have to pay the 25% of the Bid amount as fine to the GMs and then the item will be given to the second highest Bidder (on his bid amount).
7. Do not post anything else other than the Bids in the particular topic.
8. DO NOT demand to have an auction of any particular item
IMP: You cannot delete or edit your post in this particular section. So Bid CAREFULLY.
Special Rules for this Auction
1. All can Bid in it. NO Rb Limit
2. You can only Bid in ONE Anniversary Special Auction.
No post other than bidding for the item. Dont ask questions related to this auction in this thread. Any other post and all your Bids will be removed. You can ask questions in the thread in which I announced the Special Bids (Big Auctions Coming UP)
Start Bidding and make sure to follow all the rules. I would also request players to keep an eye on bidders who do not follow the rules. Use the report post option to report the BID or you can PM me or Scar in the forum.
