Newbie seeking help.
WildDrive
Post by WildDrive »
Hello, newbie here I hope you can help me out in understanding some stuff.
I just recently downloaded and unzipped the files from the full client and patched it from A3_ManiaPatch511. I disabled the anti virus because it mentions the A3Client as a potential threat. From what I can gather, just open A3.exe and that's it right?
I did that and all I get is an extra pop up which says at the bottom: "Fail to connect FTP server" @__@;;
If it's the wrong method to do so, please help out step by step. Thanks very much.
WD. :3
Re: Newbie seeking help.
http://forum.a3mania.com/viewtopic.php?f=8&t=300
Our AutoUpdate servers are down. Please use the Bypass Launcher to start the game.
WildDrive
Post by WildDrive »
Okay, bypass launcher. I pressed Connect on the next window but I get:
The programs were open were only: firefox, A3 folder, download folder, utorrent and winamp. Sorry, I'm bad at this. >_<;;
Demented
Cynick
Cynick
Post by Demented »
Follow these steps.
- Open Bypass Launcher
- Select Launch A3 (NOT CONNECT!)
- Select Connect in the window that opens after the bypass launcher closes itself.
- Click connect fast, otherwise a pop-up comes up.
Hope this helps =P
IGN : HellArcher
IGC : Archer (duh)
WildDrive
Post by WildDrive »
I'm sorry. It still doesn't work. After following the steps you mentioned, there wasn't any response from the PC :/ Nothing, zilch. T__T;
Bauer
Arr Khallhiash
Arr Khallhiash
Post by Bauer »
tried re-installing? might help.
IGN: Bauer
IGC: Warrior
IGT: Temoz
IGKH: Genocide
All this is because your Antivirus is deleting the A3Client.exe file. Try to add an exception.
netdemon
Cullijpayhern
Cullijpayhern
Post by netdemon »
Yes, you can add this as exception.
I am currently using AVG (see below) ,,, other antivirus also allow adding exception
IGN: Netdemona
IGK: Maniacs
IGC: Archer
