Your Knighthood may form alliance with other knights or even declaring war on other knighthoods
The Requirements for Creating a Knighthood
If you want to create a Knighthood as the Captain. You must meet the following requirements :
→ Character level 80 and above
→ 1,000,000 Wz
→ 30,000 Lore Points
→ A Knight Establishment Guide Card
→ A Holy Grail
How to get Knight Guide Card ?
To get Knight Guide Card, you have to implement the quest of creating a knight at Arena Manager
NPC (Quanato : Sioo or Temoz : Seniere). After completing the quest you will get a Knight Guide Card and a Magic Tree Branch as rewards. The quest is shown at Arena Manager NPC only while your level reachs 80 and above.
To implement the quest, follow the steps given below :
→ Go to Arena Manager NPC after your level reachs 80. Click on the Arena Manager and then
select "Select a Quest".
→ You will see the quest "So you want to create a knight's order?" in quest list. Take the quest and implement it. The quest require you to kill 10 Ewealla of Rangdel 4th Floor and return to Arena
Manager NPC with it's heart.
→ Bring the heart of Ewealla back to Arena Manager NPC and claim your reward consisting of a Magic Tree Branch & Knigthhood Guide Card.
How to get a Holy Grail ?
To get a Holy Grail, You must first meet the following requirements :
→ A Knighthood Guide Card and a Magic Tree Branch. This means that you must first complete the quest of creating a knight's order at Arena Manager NPC.
To get a Holy Grail, follow the steps given below :
→ First you need to make a party with other three players above level 50, who are the citizen of the same coutry.But I Prefer that one party member must be mage who can pan and sedim to find the door.
→ Go to the Statue Wolfreck ( for Temoz citizen ) or Statue Elkenver ( for Quanato citizen ) with your three party members. Click on the statue.
→ Then the "Knighthood Quest" window appears. Select the "Talk" tab, you will see a quest and requirements as shown below. Click on "OK" button to move to the Hidden Altar and implement the quest.
→ Then you are moved to a maze. You must kill all monsters in the maze with your party
members. Once all the monsters are killed, search for a key which will appear on the floor.
must pick up the key.
→ After you get the key, you must find the correct Entrance to the Room of treasures out of 6 light doors in the maze. If you click on the wrong door, you will be ask to check requirements,try to the next door until finding the correct Enterance to the Room of treasures.
→ If you succeed in finding the correct door, you will enter the room of treasures. Your party members will be trapped in a cage, you will have to alone face the Kwoan the warrior. Click on his sleeping statue to begin the battle. Once you defeat Kwoan, a Holy Grail will appear on the floor and pick up the Holy Grail from the ground.
Note : You have only 10 minutes in the maze. You must complete given quest 10 mins, if not, you will fail the quest and need to start from beginning.
→ You will return to Statue Wolfreck ( for Temoz citizen ) or Statue Elkenver ( for Quanato citizen )by proceeding into the portal.
Create a Knighthood
Once you meet the following requirements, you can create a knighthood :
1,000,000 Wz
30,000 Lore Points
A Holy Grail
To create a knighthood, follow the steps given below :
→ Click on the Statue Wolfreck ( for Temoz citizen ) or Statue Elkenver ( for Quanato citizen ).
→ Select the "Establishment" tab as shown below. Enter the name and password, retype password
for the new Knighthood. Name within 12 characters, password within 8 characters. Then click on
"Send" to create the new knighthood.
Adding a logo for your Knighthood
You can personalize your Knighthood by designing and adding a logo for it. To adding a logo,
→ Create a logo image that must be the dimensions 20 x 20 pixels in bitmap (.bmp) file format.
→ Locate the CountryWar folder, place your logo file into the folder called Emblem.
(e.g.: C:\CountryWar\Emblem\)
→ Go to the Statue Wolfreck ( for Temoz citizen ) or Statue Elkenver ( for Quanato citizen ).
Click on the statue and then the "Knighthood Quest" window appears.
Select the "Knighthood Crest" tab as shown below. Click the logo file in the File List, and press "Send"
button to add the logo for your knighthood.
Note :To add logo need 2 Bil WZ and 30,000 lore points.
How to Join a Knighthood
Hold "ALT" Key on your keyboard ;
Move mouse over the captain of the knighthood you wish to join ;
Left Click on the captain of the knighthood ;
Then a mini-menu appears. From the mini-menu select the helmet Icon as shown below ;
Then a window appears. Click on"Join Knighthood to send your application to the captain of knighthood .
The captain of knighthood will receive your application to join knighthood ;
If the captain of knighthood accepts, you will become a member of the knighthood
Note : Members need to be at least level 50 to join a knighthood. A knighthood can have max.13 members.
How to form Alliance with other Knighthood
Only the captain of knighthood can request an alliance. To form an alliance, follow the steps given below :
Move mouse over the captain of another knighthood you wish to ally ;
Left Click on the captain ;
Then a window appears. Click on "Knighthood Alliance" to send your request to the captain ;
The captain will recieve your request to form an alliance ; If the captain accepts,
your knighthood will form an alliance with the knighthood.
Knighthood Window
Open the Community window by pressing the key "C" and select the "Knighthood" tab.
Here the captain and members of knighthood can manage own knighthood.
The knighthood window of the Captain as shown below :
The captain can disband the knighthood by pressing "Disband" button; banish a member by
pressing "Ban" button; remove an alliance by pressing "Leave Alliane".
The knighthood window of the Member as shown below :
The members can leave the knighthood by pressing "Quit" button.
How to Declare war against other Knighthood
Your Knighthood may declare a war with other knighthood. This is a war system between
2 knighthoods. Each knighthood is required to produce 100,000,000 woonz to declare the
war. They will fight for a certain period of time and the winner at the end wins the total
share of 200,000,000 woonz.
Only the captain of knighthood can declare a war. To declare a war, follow the steps given below :
Open the "Declare War" window by pressing shortcut key "U" as shown below.
Enter the name of another knighthood that you want to declare war with.
Click on "OK" to send your request to the captain of another knighthood.
The captain will recieve your request ; If the captain accepts,
your knighthood will be in war state with the knighthood.
KH War Info window
Open KH War Info window by pressing key "F". Here the members of knighthood
can see all information about the current war.
By selecting "Enemy Knighthood" tab, can see the names of the enemy knighthood
and enemy alliance. The captain can here request armistice by clicking "Request termination of war"
and surrender by pressing "Surrender".
By selecting "Allied Knighthood" tab, can see all names of allied knighthood, Start/End time and the current result.
Have a peaceful war
