About maximum hp and hk heal skill
sahil7895123
Post by sahil7895123 »
Hi everyone
I tried to search in the forums but was unable to find anything.
Is hk heal restricted? I noticed it doesn't heals the full bar.
My second question is what is the maximum hp bar a character can have? Is there a limit?
-Sahil
IGN: Sahil
A3 Mania
sahil7895123
Re: About maximum hp and hk heal skill
Can any gm please respond?
IGN: Sahil
A3 Mania
Most of the time, this skill doesn't heal full HP bar. Reason is if hk's full heal is implemented, war will be boring cause no one can kill him.
What's the level of your Heal skill?
barbarch
Post by barbarch »
Regarding maximum HP.
Your HP bars length depends on two things 1) lvl of char. 2) the number of points you add to "vital".
The higher the Vital goes the higher goes the HP bar. In mania by default the vital and Mana. Both grow steadily at every level.
Have an look on your own.
All the best
coolsmanak
Post by coolsmanak »
even I think it should be solved. I am playing hk from last 10 days and my HK is RB 11 Aura 5 with Hp bar of 10k above and while using Heal Level 3 it does not heals completely.
check if this is not suppose to happen GM Blade.
Check if your character is exhausted.
coolsmanak
How Exhaustion works? If the HK is 10% Exhausted Heal wont heal a full HP bar? where i can read thoroughly about Exhaustion GM?
When a character is exhausted, all of your skills will be less effective. When you get fully exhausted, your Defense will become 0.
sahil7895123
[GM]Blade wrote: Fri Aug 25, 2017 7:12 pm What's the level of your Heal skill?
Heal level 3. Even when my character is not exhausted there are tyms when heal does not replenish hp bar to 100%.
Apologies for late reply.
IGN: Sahil
A3 Mania
forever
Dark Saint
Dark Saint
Post by forever »
Pardon me if I am wrong. Having played a holyknight at RB 12 Level 165, even I face the same thing. HK heal level 3, doesn't heal 100% at 15k bar. It only heals 30% of your bar.
As Blade has mentioned, this is definitely an issue with the character getting exhausted. Even with Less than 10 exhaustion, your skills will start becoming less effective. This applies to all skills and every class, however the Heal skill of HK is much more noticeable. Every other skill you can't really make out if it's 100% effective or not.
When your heal is not working to the full potential, just visit a Healer and try again. It should work fine once you have recovered from exhaustion.
sahil7895123
[GM]Scar wrote: Tue Aug 29, 2017 11:04 pm As Blade has mentioned, this is definitely an issue with the character getting exhausted. Even with Less than 10 exhaustion, your skills will start becoming less effective. This applies to all skills and every class, however the Heal skill of HK is much more noticeable. Every other skill you can't really make out if it's 100% effective or not.
Thank you for your response.
My old character was a Hk and it was created when the server was launched. I still remember the heal skill effect even when i was 80% exhausted. My full bar used to heal , that is the reason i can notice this as a new change. I also never noticed this difference when i played a3india(sify).
But tell me something, I have purchased RN and RR so I shouldn't get exhausted, correct? Hence my heal should work at 100%.
But if you guys say so then let me test this.
IGN: Sahil
A3 Mania
sahil7895123 wrote: Wed Aug 30, 2017 3:49 am But tell me something, I have purchased RN and RR so I shouldn't get exhausted, correct? Hence my heal should work at 100%.
https://www.a3mania.com/redyan-necklace-options
Decrease in Fatigue of 50%
While hunting, your character often tends to get Exhausted due to continuous hunting activity. This option prevents Exhaustion rate by 50%
It actually slows down the exhaustion rate but doesn't totally prevent the character from getting exhausted.
