Unable to connect
Zorphia
- Lirox
Unable to connect
Hi sudden in morning my game crash and whn i try 2 open again it goes till launcher thn whn i press connect the login screen dint came..
tried re instaling patch.no effect..!:(
IGN: Zorphia
IGC: Archer
IGT: Temoz
IGKH: ƒerocious
Rabellu
- Foman
Re: Unable to connect
Hey Zorphia
I have also faced same problem with other a3 clients. All i do is restart my pc nd it start working. But if game is still not working for you then try one of following.
1. Delete the installed game nd restart your pc. After restarting reinstall the game, patch it nd update it. After updating again restart pc nd then try running. Hope it works.
2. If above solution do not work then try using system restore. I think you can find system restore opt in start-> accessoris or in control panel. Select the latest restore point available. It will restore ur pc to the date on which that restore point was created nd you will lose ny windows update or software installed after that date although u wnt loose nd other data u copied to ur hdd.
3. About 99% chances r that 2nd method will solve ur prob. But if still prob not solved then reinstall ur operating system.
Cheers,
Nightmare
Cheers,
Nightmare
I want my status to be Rabellu not this KnowledgeBase
it happens when the A3Client.exe process is already running in the background. Open the Task Manager and End this process or try to restart your computer. This will fix the problem!
Zorphia
- Lirox
Thnks Nightmare
System restore worked:)
IGN: Zorphia
IGC: Archer
IGT: Temoz
IGKH: ƒerocious
Zorphia
- Lirox
Same prob again did system restore mny time no effect..
IGN: Zorphia
IGC: Archer
IGT: Temoz
IGKH: ƒerocious
Rabellu
- Foman
Make sure you are restoring your system to a date before the date you faced this problem for first time.
Second you can try is that boot ur pc in safe mode nd try full system scan for viruses. Also dwnld antispyware frm http://www.spywarebegone.com nd run full sys scan.
If still not solved then
3. Instead of booting in safe mode select the opt "last best known config when the sys worked"
But if it is not because of virus then i doubt these solutions to work still u can give them a try.
Because facing same prob within one day after using system restore indicate that some of files of your operating sys might have got corrupted.
By chance ny of above opt works but u again face the same prob after some time then last nd best opt is to reinstall ur operating sys.
Zorphia
- Lirox
No use re tried every thing even formated the pc no use..
IGN: Zorphia
IGC: Archer
IGT: Temoz
IGKH: ƒerocious
Try this..
Open Data folder and look for the file vn.ini. Open it and change 510 to 508. Let the updater run. Once done, try to connect to the game.
Zorphia
- Lirox
did tht to.. jst t comes till loading screen thn crash..
IGN: Zorphia
IGC: Archer
IGT: Temoz
IGKH: ƒerocious
