[6th November] Game Update Changelog
Elite Super Shue Changelog
Level 140 Elite Super Shue
Level 140 Elite Super Shue has been launched. The new super shue provides Decreases Opponents Defenses by 2% (Normal and Elemental) for each level after Level 130.
The ESS is currently being tested out for functionality and the first 140 ESS will be handed out to the 11th Anniversary Auction winner. Everyone else will be able to level up their 130 ESS at a later date.
New Larcs Added
Sprint Potion
Increases movement speed for 4 minutes
Price: 5 Mark of Rubal (Premium Item) ~ Available as a Stack of 5
Rubal's Elixir
Grants special abilities based on character class. Lasts 4 minutes.
Price: 1 Mark of Rubal (Premium Item)
Void Stone
Reduces Cooldown of Skills when used. Lasts 4 minutes.
Sus
Increases accuracy by 5% for 4 minutes and reduces evasion by 2%.
Price: 500,000 WZ Available at Morgana (Proxima)
Asus
Increases accuracy by 10% for 4 minutes and reduces evasion by 2%.
Price: 1,000,000 WZ Available at Morgana (Proxima)
Rubal's Elixir
Special Class Based abilities granted by Rubal's Elixir as as follows.
Warrior
Returns 50% of incoming damage onto the opponent who deals the damage. Applies to both Melee and Skill damage. The effect is not fatal implying that the opponent hitting a Warrior on this effect will loose HP but will not die.
Mage
Increases magic damage by 3 times when under this effect.
Holy Knight
Drains mana 50% of the damage dealt to opponent.
Archer
Converts 50% of damage dealt on opponent to HP.
Things to note.
  1. These effects only work on Players and will not work on Monsters or Bosses
  2. These effects cannot be dispelled. Freewill or Freedom will not remove these effects.
  3. Disconnecting from the game will cause the effects to vanish similar to other larc effects.
  4. These larc effects will not work in Arena and will be immediately cancelled if you enter the Arena lobby.
  5. A visible indicator as depicted in the above images will appear on top of the player to indicate the larc's active effect on the player.
Void Stone
Void Stone has the ability to reduce the cooldown of majority of the skills so that you can instantly cast them.
You will be able to see the above icon on top of the player to indicate if the larc effect is active. Note that this larc will not reduce the cooldown of skills which are already under a cooldown before usage of this larc. Only skills used after using the larc will have reduced cooldown.
This larc effect cannot be removed by Freewill or Freedom.
Misc Changes
These are the additional changes that have been made available.
  1. Redyan's Necklace now has an extra option Prevention of item loss upon death (murderers excepted)
  2. Grade 8 Unique Set will provide Evade Nullify Skills by 20% (Freedom and Freewill) when you wear all 3 Unique set parts.
  3. Wearing a Full Grade 10 set (5 Parts) with a Grade 10 Weapon will give you Increase Vitality by +1000 option.
  4. Morgana now sells special potions and larcs, specifically Milarc, Sus and Asus.
  5. Su Fon (S) (M) (L) and (G) have been added to Morgana (Proxima NPC) which will reduce 15, 30, 45 and 60 incoming damage respectively.
  6. Prices of Majority of the Premium Larcs have been revised.
  7. Sareu larc provides instant Boss Debuff removal when used.
  8. Arpone will cause the monsters in a 3 block radius to go passive and will only attack if hit first.
  9. Feararr has been added to the Premium Shop which will provide you 10% accuracy for 4 minutes without any penalties like Sus or Asus
  10. Most of the un-used RB items have been removed from the Premium Shop.
  11. Improved the positioning of Larc icons and Boss Debuff icons to properly align and conserve game display space.
  12. Fixed an issue that causes few winning player names to be missed during Tower of Desire announcement.
  13. ESS will start loosing HP when the player is attacked. This applies to ESS of any level and the damage taken will be reduced as the ESS gets to a higher level.
Re: [6th November] Game Update Changelog
Holy Knight
Update: 6th December 2019
Mana drain percentage increase to 50%
