RN opt difference between other server and this server
starranga
Post by starranga »
In every a3 server RN has 50% reduction on using hp/mp which means if any one who uses RN+Larteck that char no need to pot Mp for any skill he uses (means unlimited mp), this is the only server where I am seeing limits on RN that mean RN in this server don't have any value than just refilling 30- 100 hp per sec for ur 10k+ hp bar which is very disappointing, I just like to suggest GM's restore RN's original opts
And guys pls support this topic
Re: RN opt difference between other server and this server
It's not possible to use skills with Unlimited MP. This is by design and we don't intend to change this.
starranga
Post by starranga »
Only in this server am seeing this type of opt for RN+Larteck, chk in other servers u will know the opt of RN or shall I post a screenshot ?
starranga wrote: Sat Jul 10, 2021 8:05 pm Only in this server am seeing this type of opt for RN+Larteck, chk in other servers u will know the opt of RN or shall I post a screenshot ?
This is a server centric feature and it's intended to be like that.
@starranga dude
I think the intention is to make the game a little hard as you also be refilling mp while bossing or PvP.
But you will get used to it once you play a bit longer.
And yes, mania is different than other A3 servers :) , there is a reason why it's still running :-bd
RN and Iarrtek both have 50% reduction in MP usage, however both those options shouldn't stack. You should only get either the 50% option from the RN or the 50% option from the Iarrtek active at one time. If both are active, it's a bug. Most servers didn't fix the issue because of technical limitations and lack of planning.
We could address the bug, but instead chose to provide different options for the RN instead so that it will be more useful rather than having 50% reduction option that wouldn't stack with other rings.
starranga
Post by starranga »
Nice explanation , am convinced ha ha ha
