Looking for a master guide for Archer
soulslashers
Post by soulslashers »
Hey guys, returning after 10 years. I have my archer (Firelord) RB12 165. I see that stats of my archer & merc etc has been reset. Wanted to check which armour set is recommended or if any mix is recommended. I assume Grahsat + Arnir is still the recommended weapon. Basis this, I will distribute my points.
Sorry if this is a repeated post.
IGN-Firelord
IGC-Archer
IGKH-Dragons
shashup8097
Re: Looking for a master guide for Archer
Post by shashup8097 »
Hello buddy, I'm relatively new, not an expert archer but here is a bit of update for ur current confusion
Rb system has been restructured and so are all the stats and monster health pools
Grassat arnir works fine alongside Sunitz
for armor, g10 or unique works fine as per your playstyle, or you can imbue g10 stats onto unique armor kit using the oblivion shard update
but it's one hell of a grind
I hope an actual archer helps u out further
Happy hunting :)
aashish80
Post by aashish80 »
You will definitely need Sunitz because sometimes on boss alongwith your HK meerc you will need more range than what Grahsat offers. Arnir is defensive (for months I have played without it). PK is part of the game and with either SavingScroll/RN you can rather enjoy it. At lower level or at less than RB 12 A5 you can skip Arnir.
To begin with you need grahsat, next sunitz and finally arnir alongwith the two.
As for armor get 3 G10 armor items and 2 uni armor items if you are farming char otherwise for PvP get 4 uni + 1 G10 (G10 should preferably be crossbow pants). Most players get full G10 crossbow and full uni kit and keep swapping between items.
You can get help to make the kit dot max or lvl 10 but best to buy it from NPC (plain) or in a good deal as dot max from some player.
Kelledeegs
Kelledeegs
soulslashers wrote: Wed Aug 07, 2024 9:26 pm I assume Grahsat + Arnir is still the recommended weapon. Basis this, I will distribute my points.
It's still a recommended weapon combo.
