Item Loss on Death
There was an existent bug, which prevented Item loss on Death if you are having Parole. We have fixed that issue and hence, if you have Parole, your Inventory and Wearing items may drop off.
More information about Parole and Item Dropping.
1. Being a Commoner, you will have 5% Item drop chance when you die. This means 0 Parole.
2. As your Parole Increases, the Chance of Item drop will increase.
3, If you are a Murderer (Parole more than 600) then your Items will surely drop.
4. Weapons don't drop. This doesn't include Shields.
5. If you are a Murderer and anyone PlayerKills you, Your Items will drop.
6. Same rules apply to the Mercenary Items. Except the Weapon everything will drop depending on your Parole.
7. 1 Shot Death have more chances of Item dropping. Items placed in the F4 Slot in the Inventory have more chances of dropping.
8. Mercenaries in the Attack Mode loose Stuffs more often.
Inorder to prevent the Item Loss, you need to use Redyan Necklace or Saving Scrolls.
1. Saving Scrolls Help you prevent Item Loss. If you Die, the Saving Scroll in your Inventory will vanish, hence preventing your Item loss.
2. Mercenary items also require a Saving Scroll to save them from dropping. However Two Saving scrolls are required if the Character and Mercenary both die at the same time.
3. You may also use a Redyan Neclace to prevent the Item loss of both Mercenary and Character. It prevents the Item Loss of Mercenary if equipped by the Mercenary or it Prevents the Item Loss of Player if equipped by Player.
4. The above 2 Methods don't work if you are a Murderer. Also note that Redyan Neclace may be dropped if you die as a Murderer.
Additional use of Saving Scrolls and Redyan Necklace is that if you die at an Aura Level (160-165), you will only loose 0.50% Experience.
This Changes will be made on 19th June 2009...
Note: You need to take Care of all your Items to prevent them from dropping. We will not entertain any requests for Item Retrievals. This Includes Membership and Eshop Items Also.
Item Loss on Death
Item Loss on Death
