With great effort past 3 days, we have implemented the Elite SuperShue (Also called Super Super Shue
1. We have enabled Leveling Past 100 for any Normal Supershue.
2.You will NOT be getting any EXP from the Monster Kills.
3. You need to Level up your Shue using Neryidars.
4. Initially we have released leveling till Level 110. At Level 101, Your shue will have 3 Times Attack and 2 Times Defence. That means at Level 100, you have 200 Attack Power and 100 Defence, whereas at Level 101, you will be having 303 Attack and 202 Defence. This means you get more than a normal level for the shue.
5. We have removed Neridyar G from the NPCs. You need to acquire it by Hunting alone.
6. When you equippe an Elite Supershue, you will get a confirmation message that the Supershue has been equipped, Indicating that the Effect of the Elite Supershue is in Play!
7. There are some issues with the HP bar of the Shue. They are permitted to full upto 63 HP, and the Statistics shown on the Supershue are not according to the Changes that are made. A Proper fix for this will be provided in the Upcoming Client Patch.
These are the Changes in the EXP rate of the Neryidars.
Before Level 100:
After Level 100:Neryidar (S) - 5 EXP
Neryidar (M) - 25 EXP
Neryidar (L) - 50 EXP
Neryidar (G) - 2500 EXP
Neryidar (S) - 1 EXP
Neryidar (M) - 5 EXP
Neryidar (L) - 10 EXP
Neryidar (G) - 250 EXP
If there are any bugs with this, let me know Immediately.
Hope you like this Implementation.
