How can an archer Beat Dex Uniques?
bonghitz
This is a question I have. I have played a few servers of a3.
Looking for those archer pro's out there who can answer this question.
Greendragon
- Tizor
Re: How can an archer Beat Dex Uniques?
well... i'm no pro. and not even close to good @archerbonghitz wrote:This is a question I have. I have played a few servers of a3.
but i'd like to give my thoughts.
Archers can beat dex unique guys...
1. hk -> key is to make them busy buffing n debuffing & miss razz n stuff on you. high evasion high magic evasion helps. there are tricks where u can make hk warp around(i know a person that uses it so well but thats a secret ;) ) also vice versa. hk can sneak in a few moments where u are not able to do anything (this one's got to do with your timing a good hk can get you screwed)
in short: be as unpredictable as u can & try to make use of any opportunity to hit them back
2. warrior -> run-hit/dont get hit. Tough to beat them especially ones with crystalline. but there are strategies to work around it.
3. Mage -> timing is important. make use of ur faster hit speed & skills to sneak in non-hp absorber shots
4. Archers -> set options, passives & gameplay (although seems gameplay tends to be a little futile as some just keep hitting standing still hoping to miss less) weapon range also comes into play. more the range more trouble for the opponent
IGN:- Greendragon
IGC:- Holy Knight
IGKH:- Maniacs
IGT:- Quanato
IGC:- Holy Knight
IGKH:- Maniacs
IGT:- Quanato
nimesh1987
- Es Higel
Hail to sir GD..great post and that archer's name is Ghostwalker and Stalina
IGN-Nightqueene
IGC-Mage
IGT-Temoz
IGKH-Darkknightsâ„¢
IGN-Nightqueene
IGC-Mage
IGT-Temoz
IGKH-Darkknightsâ„¢
alex
- Dark Saint
Its impossible to beat GD.. Rest all G10 hks dun play gud u can get em if ur quick enuf... bt dat holds if the match is non-dex..
deadraizer
use ur range to d maximum, try nt to tank as much as possible, whn u hv to tank, tank wid ur dex in hands, and whn ur hitting 4m far, try to give as many shots as possible, G10 bow cud cm very useful in this situation, b'coz it has awesm range and attack speed
this may help u, bt I've nt played archer much, so this cnt b called a pro's advice
IGN : Deadraizer
IGC : HK
<3 <3 <3 <3 <3 <3 <3 <3 <3 <3 <3 <3
bonghitz
thank you for all your help i really appreciate it.
You can get all this info, If you are able to post it at the right place to the right people
rockstar8
its every easy to blow up any class player in a3 india wid a dex also playing an archer...
but this server feels very different...
maybe in arena hks may die even on dex...but in maps forget it...
archers were always mage killers...warriors can never win against archers if the archer plays properly!!
bonghitz
[GM]Scar wrote:You can get all this info, If you are able to post it at the right place to the right people
Wow , Your a GM ?
Your cryptic message does not help me out any.
How about giving me some help instead of .... well whatever you were trying to say.
deadraizer
lol he's a GM
IGN : Deadraizer
IGC : HK
rockstar8
uni mace or axe = archer's fright!
Rabellu
- Foman
Scar was pointing to your post in rz i think.
You had got great answers there even if they were of no help.
But at last you are in a3mania. And this is right place to ask for such things.
I would suggest you to play nd develope ur own unique gameplay. Asking the others wnt help much. Play, experiment nd learn. That's the best way to raise a strong char nd then you can beat the dex players.
I want my status to be Rabellu not this KnowledgeBase
deadraizer
true said, experiment wid ur own char is d best way to learn d game
IGN : Deadraizer
IGC : HK
ynot2005
well first of all archers are deadly but must be in deadly hadns ;)
accorning to me...
HK : Tuf to beat if he has good gameplay.. My friend mervin (IGN : Excorcist and airesknight in a3india) would kill me without using 1 hp also.. lol.
Mage : too easy run around dodge sbs and kill..
Warrior : again run around and dont get hit.
Archer : Gameplay a its best.(Know when to buff and debuff)
IGN : not yet decided
IGT : Will be Quanato
IGK : Will join someone or create my own ^.^
Regards..
Ansel
accorning to me...
Regards..
Ansel
deadraizer
@above
HKs shud usually kill widout using HP, most of d tym (whn it used to b 100% heal) either HK wud defeat u widout using a single HP pot, or else hed lose, coz an HKs hp runs away lyk hell whn potting
IGN : Deadraizer
IGC : HK
