I can login the game through the A3Launcher.exe.. One day I couldn't go to a map from Sky Gate. I came to know that i haven't updated my client. I tried opening the "a3.exe" file. Then it opens a Updater and then suddenly open Connect window. I click it and get incorrect version
1st . I click this and open
2. Project Updater window comes. Stays for a second or two and then i get this
Run A3.exe, It should show an entirely new Updater with an Archer Picture on it. It should update the client from 507 to 508 and you get to see the Maps and Creeps.
A just little change. Just extract the A3.exe from that zip file. 1st I did for all files and failed to update. Then i tried for only a3.exe and Kaboom! client update started showing archer pic
Hi GM,
i downloaded A3mania_Client(426,728 Mb).and extracted wid 7z 1st its extraced to 228mb files only rest all Error Data didnt extract..thn tried at WinRAR tht also same..after i extracted patch even tht patch data's also showing error..this is not only for me many ppl got same prob..
dare_frenzy wrote:Hi GM,
Redownload. The downloaded archive got corrupted for you.
Or you can also use any other epi 5 client in english version nd patch that client with 7mb patch available on a3mania webpage and game will run smoothly for you.
Active on Forums only not ingame. I want my status to be Rabellu not this KnowledgeBase
