Change in Merc Rebirth System
Hello Gamers,
As you all are aware that we have had serious problems with Mercenaries, with more than 200 lost Mercenary cases, we have finally come up with a fix.
Inorder to come up with a fix, we will have to reset the Mercs and Totally REMOVE the Merc RB.
We have planned the Following:
1. Merc RB will be TOTALLY REMOVED. There will be NO Rebirths for Mercenary.
2. All the Mercenaries will be Restored to Level 1 with Starting Stats, 0 EXP and No Passive Skills.
3. Merc Will acquire 20 Skill Points, 2 MSP Points Per Level
4. Hunting and Quest EXP of the Merc will be 10 EXP per Quest or Monster Kill
5. Merc will loose a Standard of 1000 EXP on Death.
However, we will be Implementing Rune of Faith inorder to give Extra Hunting EXP to the Mercenaries.
Important: Please remove all your Equipped items from the Merc. We are not responsible for any cases of Lost stuffs due to carelessness. We have already warned you! We will not entertain any such requests for Stuff Retrieval. Hence, Remove all your Equipped items from the Merc and wear them accordingly.
Some New Updates are being added by GM-Scar. Server will be down early on 4th April 2010 for the changes. A new patch is Anticipated.
