err i got thru the problem by setting avg status to ignore the a3 mania path
But i hav another problem
At the connector screen it say invalid user id even though i logged in with
the same account at the forums and i m still using it to type even this post.
But plzz say solution or i cant play
Dude a3 server ID's nd forum ID's are totally different.
You have to register id on a3mania.co.nr and login to game with that ID.
Forum ID will not work in game.
Active on Forums only not ingame. I want my status to be Rabellu not this KnowledgeBase
rooney8 wrote:err i got thru the problem by setting avg status to ignore the a3 mania path
According to new patch the server version should be on 5.08 but when i update teh patch iots shows teh client is been updated but when the screen cm its shows version 1.17
n according to new patch NC for sure drops but when i hunt in NC bosses do go SAD...
So help me out wht i need to do to fix this problem....i hv trried extracting teh pach n updating it again n again but the version remains 1.17 n i use updater a3mania updater to launch the game...
Don't follow the version displayed on the Launcher. Follow the version that is displayed on the Updater.
The chances of Drop Less Nevia Boss are decreased, but the drop rate is not 100%. There might be some drop less bosses.
If you are able to see Grnita Park Creeps and the Map list in the Sky Garden NPC, then your client is 508 version!
