New Additions:
1. New Town Proxima Added.
2. New NPCs added in the town.
3. New battleground map added in Proxima. Only one map currently in the teleporter in Proxima. This map will be used for Thol wars. The map is a free PK zone. No XP loss or anything. Have fun.
4. Teleporter to Proxima is located in a Map in the Normal World. You have to find it out. We are not telling you or giving any hints.
5. Clicking on the NPC will port you to Proxima. You will have to be very near the NPC for the click-port to work.
6. There is a certain criteria to port to proxima. If not met, an message will pop up in yellow. Notice it and follow the instructions. You have to figure out yourself. Easy.
7. After porting to Proxima check everything. A huge surprise is waiting.
8. If you dont have gameplay, you will suck bigtime there. You will know why when you go there.
9. After entering Proxima, you will have to re-allocate your stats. More info on this when you find out the surprise.
11. You will not be able to wear Uni set in Proxima. You will find out why when you are there. BTW we will be adding it later
12. RN will have reduced regen for HP and MP in Proxima. You will also know the reason when you are there.
13. Mercenaries are not allowed in Outworld due to obvious reasons. You will figure them out once you get there.
PS: You might be able to enter now with mercs and etc. Will be changed soon.
Fixes/Alterations:
1. ESS stats will be displayed now correctly.
2. Episode 4 and Episode 5 maps have been closed till further notice.
3. Changed the Logo during Login.
4. Removed the banner during Login and altered the Client User Interface.
DO A FULL CHECK ON THE UPDATER. ELSE YOUR CHAR WILL GET STUCK. THEN DONT CRY.
Have fun.
