You cannot connect to the server??
				Claimurai
Hi Guys!!.. Numenor has mentioned dat d server is up (quite happy about dat
 ).. but wen i am tryin to login i get a message "You cannot connect to d server"(dissapointed
 ).. As Numenor had advised i did a full check before login in.. den too i got dis message!!.. Confused
				Hrtoin
Re: You cannot connect to the server??
Same here, before I login I see 10 Online Players ingame. But after I tried to login, no player online. Did full check after first login failed..
						- zuljaz
GM Dude!! plz post the patch or download file for updates coz our updater is not getting updated! and when running full check its only checking n not updating kindly attest at the earliest!! BTW great job keep up the good work u guys ROCK!!
							IGN:MadamX/Razors
IGL:RB10 /12 165
IGC:Mage/Hk
						IGL:RB10 /12 165
IGC:Mage/Hk
- zuljaz
I am getting client validation failed . please update your client ???? well i have run a full check as well wat wrong?? can any 1 help me plzzzz...... do i need to re install something like tht r need to download the client again >????:(
							IGN:MadamX/Razors
IGL:RB10 /12 165
IGC:Mage/Hk
						IGL:RB10 /12 165
IGC:Mage/Hk
				viperboy
 - Khastol
Same Problem here also ..
Completed the update .. done full check several times ..
stil when i try to login it says 'cannot connect to the server'
       IGN -  Modsoul, Romulas
M0D I$ Ur G0D !!
Messenger Of Death
Legends Live Forever
						M0D I$ Ur G0D !!
Messenger Of Death
				Aarizona
Cannot     Logging
A a r i z o n a
						A a r i z o n a
				anilxplod
 - Es Yahgon
too sad here...
sala u guys at-least can do full chk here i m nt even able to do that also
stopping at A3client.exe
IGN=Unstopable
IGL=RB 11 LVL 165
BORN Q AND CN DIE FR Q
I never back down from any challange put in front of me
						IGL=RB 11 LVL 165
				Aarizona
Abe anil noob . me too getting stop in between.
						- Shivprasad
We Cannot Connect to Server .. Why So?
Quanato dont rule me ! I Rule Quanato !
- vehla_sarpanch
 - Moulek
You ppl will get stuck because a3exe file which u ppl use to run the update is not same bit as ur windows.. if u using 64 bit download a 64 bit specified a3exe file and same goes for 32 bil file
							IGN: Stalina, Jattsta
IGK: DarkKnights
Flowing like a lube~~!
						IGK: DarkKnights
- Shivprasad
Even i Re-install the 562 Client .. but Still same problem ..
Nume reply in this pls .. w8ing to eagerly see new things ..
				bobalki
[u][b]Noob GM and Team[/b][/u] server still down and "chutiya" saying server up............
No server r up and ever gonna going to up.........
All dont waste time .... go on to ur work.....
bullshit this server , game n funking gm's lol....
				Pain
 - Skicaboreck
"Failed to Login Server"
							£€G€ÑК ÐøÑ† С€......... Wë K¡££ TH€M.......    !!!!!!
IGN: Recobeast, BunnyFastard, Cybertooth
IGC: Archer, Warrior
IGKH: Akatsuki(Leader)
				PoSiEyDn
Hi !!! are keep patience all of u again server is closed bcoz of some problem they closed the server,  so it might be open today or tommorow or after 2 days
  so all chill hahahahaha dont do anything to ur client or server chalu hone se pehle computer kharab ho jayega
regards,
GM Scaremonger
						regards,
GM Scaremonger
				anilxplod
 - Es Yahgon
Aarizona wrote:Abe anil noob . me too getting stop in between.![]()
O_o control ur speech dear .......
IGN=Unstopable
IGL=RB 11 LVL 165
						IGL=RB 11 LVL 165
