GM PLZ HELP ME to get rid of ths prob..........
NoOne
Post by NoOne »
Whn am trying to launch a3 My pc going restarted.. Its starting is ok.. bt at d tym whn logging page cm its going restated... Windows Xp(service pack 2) , .net framework 3.0 is also installed..
Smtime its nt going restarted bt kicking frm a3 wd a message"corrupted file; reinstall client" bt i hv tried almost 10times... same prob evry time..
Whn am clicking twice on a3 updater.. Its Showing "runtime error 91" ""object variable or with block variable not set""
PLZ HELP ME ~x( :-ss :((
IGN= Magnaflo
IGC= Warrior
IGL= Rb12 lvl165
IGKH= Whysoserious
Roflmao
Re: GM PLZ HELP ME to get rid of ths prob..........
Post by Roflmao »
chicha do as i say
1- download a3 mania patch frm a3mania site
2- patch ur client
3- launch a3
4- full check
5- start mania gr8 gaming :P
If doesnt it doesnt get solved
den hop GMs reply to ur post
IGN-Rofllmao
IGL-Rb12 lvl 165
IGKH-HolyRetards™
IGC-Archer
»Not Active Ingame But Partially Active in Forums»
Chatsification
Post by Chatsification »
Seems like its a recent problem. Have you done anything lately with your operating system? I mean to say, any changes??
I have recieved those sort of error while starting the game from Sandboxie.
IGN - Tzar ; Aurhyon ; Rupture
IGKH - Akatsuki ; Sharinghans ; Fightclub
sahil
Cullijpayhern
Cullijpayhern
Post by sahil »
Restore ur comp by clicking on system restore(i hope u knw abt this)
Start A3 after doing a full client check.
IGN: Sahil
A3 Mania
NoOne
Post by NoOne »
@Sahil Srry i cant get u... Can u plz show me d steps???
@Chat Only Format nthing else... & installed .net framework 3.0 & direct X 9... Both r installed properly...
@Chicha I hv already done all of this.. BT Same Prob Evry time.. :-ss Now Am getting angry on My Comp.. X( dunno how to solve this prob :(( Need Help Badly =((
IGN= Magnaflo
IGC= Warrior
IGL= Rb12 lvl165
IGKH= Whysoserious
sahil
Cullijpayhern
Cullijpayhern
Post by sahil »
bhai a computer creates a restore point before getting the windows update or after a fixed interval( dont knw when bt it does) so when there are tricky problems like this, the easy solution is opening the system restore and choosing the restore point. Your Pc gets restarted and when u login your pc is restored to a specific time period this means any type of software or update in already existing software's gets removed and it performs as it was on that specific period. Files such as Word or PDF file remains same so dont worry.
Click on windows and search for system restore
Just perform as instructed.
I hope this solves your issue.
If this doesnt help try Formatting ur PC the ultimate option
(Windows 7 ke zamane main windows Xp ?, update karo apna PC hehe)
IGN: Sahil
A3 Mania
Make sure you give A3Client.exe Administrator Rights.
NoOne
Post by NoOne »
@ GM BLADE Dunno... How to check that?? Plz show me d steps....
IGN= Magnaflo
IGC= Warrior
IGL= Rb12 lvl165
IGKH= Whysoserious
Chatsification
The default Directory of A3 Mania is c:\Program files\A3 Mania client 562\a3.exe
Unless you have modified it.
Once your there in the folder, all you have to do is,
1) Right click on a3.exe
2) Go to properties
3) Check for the Compability Tab.
4) At the bottom you will be able to find something called "Privilege level"
5) Mark Run as Administrator out there.
Thanks. Do a full check then onwards and try to run it.
NoOne
Post by NoOne »
Thanks Chats... Weeeeeeeeeeee Launched :).. Ty all :)
IGN= Magnaflo
IGC= Warrior
IGL= Rb12 lvl165
IGKH= Whysoserious
