GM Help Not Able to Log in!
zuljaz
Post by zuljaz »
Is server down for updates or to fix some bugs!!????.. i can not log in while logging it say login to serve failed please help !!.....
guys any 1 plzz help me are u able to play d game and i have tried everything but still the screen hangs for a second and then quikly the failed to login message flashes and vanishes what to do ??
IGN:MadamX/Razors
IGL:RB10 /12 165
IGC:Mage/Hk
Re: GM Help Not Able to Log in!
Have you updated your client to the latest version?
zuljaz
Post by zuljaz »
Many thanks for prompt reply!! yes i have done a complete update of the client do i try re installing the client again will tht help !!>?? the screen just hang asa i try to login and failed to login message flashes for a sec...:(
IGN:MadamX/Razors
IGL:RB10 /12 165
IGC:Mage/Hk
zuljaz
Post by zuljaz »
Dude! i have infact uninstalled and again reinstalled the game but still it doent seem to work the same problem so i tired installing in another computer and still the same problem is this with my isp problem coz i am playing from dubai does this mean i cant play A3 any more PLzzzzzzzzzzzzzzzzzzzz!! help me guys giv me a solution what can i do ??? :(( REPLY ASAP :-\
IGN:MadamX/Razors
IGL:RB10 /12 165
IGC:Mage/Hk
viperboy
Khastol
Khastol
Post by viperboy »
I am also not able to login.. my game was running normal till 1 hr back.. then after that dcd and i am not able to login since then.. Done full check on client many times it says update complete still not logging in.. turned off firewall,antivirus and then also full checked still not logging in..
IGN - Modsoul, Romulas
M0D I$ Ur G0D !!
Messenger Of Death
Legends Live Forever
Remoo
Post by Remoo »
Same Here Also :((
zuljaz
Post by zuljaz »
PROBLEM SOLVED!!... It was a technical glitch!!.....
Guys do as i say it helped jus turn off your modem and restart it may be coz of ur ISP (Ineternet Service) so jus try doing it and let me know !
GM thanks but no thanks !! :D i solved the problem on my own and yep :-? appreciate your response :-bd
IGN:MadamX/Razors
IGL:RB10 /12 165
IGC:Mage/Hk
Chatsification
Post by Chatsification »
Not able to log in.
HIGH PINGS EVERYDAY
As soon as i type my id and password, click on the "Mania" after choosing the character, I get spammed, "Unable to Connect, Please try again later" . Not able to log in since last night. Done apparently everything to solve the issue, nothing helps.
Please let me know asap.
IGN - Tzar ; Aurhyon ; Rupture
IGKH - Akatsuki ; Sharinghans ; Fightclub
