Direct X Intializing Failed
krs aka Suraj
Post by krs aka Suraj »
Hello Respected GMs,
I was trying to login in mania Using My Laptop..
When I run updater, Updated game & Started game, it shows me an error that,
"Direct X Initializing failed. Be sure check your NetMeeting Online , Or running A 3d Game. Please execute & Run game again !"
Can u tell me solution please ?
Re: Direct X Intializing Failed
You need to run the game with a minimum resolution of 1024x768. If your laptop resolution is lower and doesn't support the minimum resolution, the game will not run. I assume you are using a Netbook.
