[8th July 2012] Server Update Changelog
Increased ESS Shue Cap to Level 120 and added new breeding system.
Please check the following link for more information: http://forum.a3mania.com/viewtopic.php?f=5&t=4341
Changes to Hamutz Bossing
Drops of Ishina, Di Ishnia and Arr Ishina have been fixed. The drops are better and more proper. We have fixed bugs with Unique Scrolls that were not dropping.
All the other requirements are similar. Rebirth 12 and special item requirement for Map Entry. Please refer to earlier Changelog posts for more information.
Ishida drops Neryidar (J) as a 100% sure drop each time, which could be used for Shue Leveling after Level 110.
Fixed issues with Map not getting unlocked immediately after the boss is dead.
Mercenary Leveling
We have implemented a new map called "Skyring" which is exclusively for Mercenary Hunting.
Players won't be able to kill the monsters in Skyring either by using Skills or Melee attacks. Only Mercenaries can hunt in Skyring.
Experience received varies with the monsters. Stronger monsters give higher experience.
There are few bosses that spawn at random time which could be killed by the Mercenary only.
A Hunting Fee of 200,000 WZ is collected every minute for hunting in Skyring. If you don't have woonz in your inventory, you will be returned back to Proxima.
As a result of the changes made to the Merc Leveling, we have reduced the Mercenary Skill Points per Level to 2 instead of 3 which was previously.
Premium Items
All of the Mark of Rubal requirements for Premium Items have been reduced significantly.
However, this is applicable only to Rebirth Items.
Arena
Fixed few bugs with Damage Calculation.
Implemented Elite Super Shue support in Arena till Level 120.
Implemented Grade 8 Unique Set options.
Implemented Grade 10 Set options.
Fixed HP potting issues with Elite Super Shue.
Proxima Orbis
Changed the position of the Whanhellz NPC to the old Place. Near the Warp Point.
Removing of Equipments is not required when entering or leaving Proxima expect when your stats are improper which would prevent you from wearing the items.
Drop Rate Changes
We have implemented a new Drop System called "Item Frequency Cycle" by which drops are randomized inorder to preserve the frequency of occurrence without sacrificing the value of items dropped.
The Drop rates of the following bosses have been effected as a result.
  • Goshualeng
    Gunge
    Kuazer
    Amra
    Irkade Mann
    Snowman
    Guanzhhiyan
    Ernumo
    ShuizhuBazi
Miscellaneous Changes
Changed Loading Screen Sound
Options on Grade 10 Armors only appear when a Grade 10 Weapon is equipped
Fixed issues with Borie NPC from which Milarc couldn't be purchased
