Title - Appear of Soul
Restriction - Level 100,Lores 100000,Quest Scroll 2-2
Reward - Lores 50000,Exp 5000000,Sj & lj
Contents - Listen to the Appeal of Soul Only those who cure their gruesomepain can open the land of prosperity.
First of all, this quest is better done in a party of 4 than soloing, since there's a lot of mobs to kill. I'd reccommend the whole party to be at least lvl 165, because time is short , and the mobs are quite strong too. There must be at least 1 mage with Whipnos which last about at least 2 minutes, and maybe a HK can come in handy.
Gather at Denenherr, X 106 Y 96, take off all mercenaries, perform the quest and here we go!
How to do Quest:
Part 1:
After listening to what Leishard say, you'll end up on a platform. You have 60 seconds to find the Cries of Spirit.
Part 2:
Nothing particular about what the Spirits say, just that 33 spirits are being captured. After finish talking with the Spirits, have each member run to a path and you'll have Deneris spawning. You'll have to kill them and they'll drop keys and they have their values. You need at least 7 keys to pass this round. Screenshots provided, showing 7 boxes (for 7 keys) have to form an equation to equal the number of captured souls, which is 33.
Values available are 3 to 9, + - x.
4 simple equations.
1) 5 x 7 + 6 - 8
2) 4 x 9 + 5 - 8
3) 4 x 9 + 3 - 6
4) 5 x 6 + 7 - 4
Of course there are many more equations, but based on the numbers , these 4appear most often. Only 2 or 3 minutes given I think, so be fast.
Sugesstion!!!Once someone gets a key, say out the value in party. When you see the keys totally match an equation, faster go to the Spirits and put in the correct combination.
Part 3:
You'll be shifted to a place where there's a structure in the middle. There will be 45 Denerians, and you wont be able to kill them using normal means. You'll have to lure the mobs down to the platform where the middle structure is, and then have a mage Whip it.
To kill them, you have to lure them down and then Whip. Make sure everyone clears the platform, and then go to the corner. You'll see a Statue of a soldier. Destroy it and the Denerians will get killed.. even players in there. Repeat until every 45 of them dies.
Since there are 45 of them, either lure as much as you can and Whip all, and kill; or kill 20+ by 20+ if u r 160 below. 4 or 5 mins given. It's kinda hard to fail
here.
Part 4:
The last part. You'll have to finish off a Phoenix, and it's really quite strong. No much advice, just that keep your hp high coz it hits hard. Give it your best attacks, it should die down before the time does. Since it's a fire phoenix (I think.) maybe ice attacks works better.
After your Pheonix Dead, CONGO SQ done
Reward -
Opening of Chlorence map
Small Juego
5000000 Experience
And also heard that Phoenix drops Redyan's Necklace
