tyzzzz
need help guyss
spider_88
need help guyss
i installed the client & the patch files but a3.exe is not ready to open.do i ned to use tht bypass but even if i do it wont connect even after press connect tab.i am new to this server pls help me get into this server.wen i press at a3mania updater i get an error as contact a3mania update server & boom no response after tht....& if possible can sm1 post steps fr installation aswell..
tyzzzz
tyzzzz
IndianKiller
- Dark Memora
Re: need help guyss
Are you connected to the Internet and does your ISP allow FTP Connections? Also make sure that the A3Client.exe is not accidentally deleted by your Antivirus. If so, re-extract the patch and add an exception to your Antivirus.spider_88 wrote:i installed the client & the patch files but a3.exe is not ready to open.do i ned to use tht bypass but even if i do it wont connect even after press connect tab.i am new to this server pls help me get into this server.wen i press at a3mania updater i get an error as contact a3mania update server & boom no response after tht....& if possible can sm1 post steps fr installation aswell..
tyzzzz
spider_88
IndianKiller
- Dark Memora
Re: need help guyss
Follow scars advice he is right[GM]Scar wrote:Are you connected to the Internet and does your ISP allow FTP Connections? Also make sure that the A3Client.exe is not accidentally deleted by your Antivirus. If so, re-extract the patch and add an exception to your Antivirus.
spider_88
Re: need help guyss
so do i hav to remove my antivirus like as for a3india???
spider_88
Re: need help guyss
and i didnt get the FTP connection thing...
Re: need help guyss
You need to allow the A3.exe to access the Internet. As you can see that your McAfee is blocking access.
