Game is not loading Login Page
HI
I am trying to Login to game, but Login page is not displaying.
Please help
Please help
Re: Game is not loading Login Page
1920 X 1080
System Information: 8GB RAM & Intel UHD 620, Windows 10
Can you please reply/help
Delete the setup.ini file in the Game folder and then run A3.exe and use Full Check option.
Followed your step, but same result. That is the last image i can see and then it redirects to desktop - killing app.[GM]Blade wrote: Tue Nov 26, 2019 4:25 pm Delete the setup.ini file in the Game folder and then run A3.exe and use Full Check option.
Also, i am attaching file from BugReport folder, kindly check.
Any1 else, playing outside India?
Please use the following client and check to see if you are able to reach the Login screen. You will have to extract the ZIP archive into your A3 Game directory and then run the game normally. Don't use Full Check after replacing the client EXE as that will replace the file with the original file.
Link Removed
Link Removed
Hi GM,[GM]Blade wrote: Wed Nov 27, 2019 5:30 am Please use the following client and check to see if you are able to reach the Login screen. You will have to extract the ZIP archive into your A3 Game directory and then run the game normally. Don't use Full Check after replacing the client EXE as that will replace the file with the original file.
Link Removed
Thanks , Yes, I was able to reach Login Screen, But then Client Validation Failed.
Glad to know that the issue is resolved.
The client is not yet validated for the game and that is the reason why you can't login. I will submit the client for validation and once it's approved, everyone should be receiving a client update to fix this issue.
Glad to hear.[GM]Blade wrote: Wed Nov 27, 2019 6:31 am Glad to know that the issue is resolved.
Looking forward for your approved client version.
Please use the Full check option. You should be able to login to the game.
It worked and played too.[GM]Blade wrote: Wed Nov 27, 2019 9:10 am Please use the Full check option. You should be able to login to the game.
Thank you
