Server Shifting
Server Shifting
Dear Players,
Due to LAG and Performance factors we are shifting the USA Server to Germany. It is expected that as a result of the shifting, nearly 80% Performance can be boosted.
SNG server on the other hand is having stability problems and Frequent disconnects, due to which we are planning to totally remove the Singapore server and use a central Germany server.
Instead of spending money on 2 Servers in USA and SNG, We are planning to go for a more powerfull 64 bit Server in Germany.
We have to make a change because LAG is hated by everyone. In this issue we need the co-operation of players.
Please post the following:
IP Address: 85.25.120.51
1. Ping
* Click on Start Run
* Type ping 85.25.120.51 -t
* Check the Time=Xms
* Post the value of X
2. Tracert
* Click on Start
* Click on Run
* Type cmd
* Type tracert 85.25.120.51
* When trace is complete, take a screenshot and post, or either rightclick, select all, press enter and paste it here.
3. Your Location and City
4. Internet Connection that you are using.
You can compare the pings of USA server and Germany
USA Server IP: 69.64.47.153
Germany Server IP: 85.25.120.51
1. Ping
2. Tracert
* Click on Start
* Click on Run
* Type cmd
Re: Server Shifting
Airtel connections have known issues with ping.
ISP: Sify Broadband.
LaxmanM
- Dark Olgoc
Re: Server Shifting
madmanzrocks
Re: Server Shifting
ping stats
max 181ms, min 172ms, average 175ms
ISP MTNL Navi Mumbai
IGN AnikeTorA
IGN AnikeTorA
Speedey
- Hwamar
Re: Server Shifting
I tested both the Pings, but unable to paste the screenshots here. Im such a noob.
Anyway, the stats are....
USA Server:
Max - 327ms Min - 311ms
Ger Server
Max - 311ms Min - 296ms
By the looks of it, Germany is better.
Im from Kolkata, using BSNL Broadband.
IGN - Anayu
USA Server:
Ger Server
IGN - Anayu
Speedey
- Hwamar
Re: Server Shifting
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\DaiYoukai>traceart 85.35.120.51
'traceart' is not recognized as an internal or external command,
operable program or batch file.
C:\Users\DaiYoukai>tracert 85.35.120.51
Tracing route to host51-120-static.35-85-b.business.telecomitalia.it [85.35.120.
51]
over a maximum of 30 hops:
1 28 ms 15 ms 15 ms 59.93.192.1
2 15 ms 15 ms 15 ms 218.248.255.22
3 62 ms 61 ms 62 ms 121.244.78.170.static-lvsb.vsnl.net.in [121.244.
78.170]
4 202 ms 202 ms 202 ms 59.163.16.154.static.vsnl.net.in [59.163.16.154]
5 202 ms 202 ms 202 ms if-10-2.core1.LDN-London.as6453.net [195.219.48.
177]
6 202 ms 202 ms 202 ms if-3-1.mcore3.LDN-London.as6453.net [195.219.195
.1]
7 192 ms 198 ms 196 ms Vlan463.icore1.LDN-London.as6453.net [195.219.19
5.38]
8 218 ms 217 ms 218 ms ix-2-13.icore1.LDN-London.as6453.net [195.219.83
.38]
9 218 ms 218 ms 218 ms lon2-lon31-racc1.lon.seabone.net [195.22.209.122
10 218 ms 217 ms 218 ms mil50-lon2-racc1.lon.seabone.net [195.22.209.211
11 218 ms 218 ms 218 ms mil25-mil50-racc1.mil.seabone.net [195.22.196.16
1]
12 * * * Request timed out.
13 * * * Request timed out.
14
-----------------this is trace for ger server.......
51]
78.170]
177]
.1]
5.38]
.38]
1]
14
IGN: Anayu
IGC: Mage
IGKH: †HâLLôWêІ
IGT: Temoz
IGC: Mage
IGKH: †HâLLôWêІ
IGT: Temoz
Greendragon
- Tizor
Re: Server Shifting
Please note that the below is the best possible. us server was giving least lag at the time i checked.
My location:
Salt Lake City, Utah
USA
Ping for US server:
Reply from 69.64.47.57: bytes=32 time=98ms TTL=114
Reply from 69.64.47.57: bytes=32 time=72ms TTL=114
Reply from 69.64.47.57: bytes=32 time=69ms TTL=114
Reply from 69.64.47.57: bytes=32 time=70ms TTL=114
Reply from 69.64.47.57: bytes=32 time=71ms TTL=114
Reply from 69.64.47.57: bytes=32 time=75ms TTL=114
Ping statistics for 69.64.47.57:
Packets: Sent = 285, Received = 285, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 69ms, Maximum = 172ms, Average = 79ms
German Server :
Reply from 85.25.120.51: bytes=32 time=200ms TTL=45
Reply from 85.25.120.51: bytes=32 time=202ms TTL=45
Reply from 85.25.120.51: bytes=32 time=240ms TTL=45
Reply from 85.25.120.51: bytes=32 time=212ms TTL=45
Reply from 85.25.120.51: bytes=32 time=206ms TTL=45
Reply from 85.25.120.51: bytes=32 time=199ms TTL=45
Ping statistics for 85.25.120.51:
Packets: Sent = 117, Received = 116, Lost = 1 (0% loss),
Minimum = 195ms, Maximum = 326ms, Average = 215ms
Tracing route to tigerwerk.de [85.25.120.51]
1 1 ms 2 ms 1 ms 192.168.1.1
3 65 ms 53 ms 42 ms ge-5-1-ur01.saltlakecity.ut.utah.comcast.net [68
.87.170.137]
4 9 ms 8 ms 14 ms te-9-4-ar01.saltlakecity.ut.utah.comcast.net [68
.87.170.9]
5 27 ms 36 ms 36 ms te-0-1-0-7-cr01.seattle.wa.ibone.comcast.net [68
.86.90.249]
6 35 ms 30 ms 48 ms pos-0-8-0-0-cr01.portland.or.ibone.comcast.net [
68.86.85.206]
7 50 ms 47 ms 44 ms pos-1-15-0-0-cr01.sacramento.ca.ibone.comcast.ne
t [68.86.85.197]
8 72 ms 70 ms 66 ms pos-0-9-0-0-cr01.sanjose.ca.ibone.comcast.net [6
8.86.85.181]
9 84 ms 81 ms 76 ms te3-3.mpd01.sjc04.atlas.cogentco.com [154.54.11.
105]
10 92 ms 103 ms 83 ms te8-2.ccr02.sfo01.atlas.cogentco.com [154.54.7.1
73]
11 82 ms 81 ms 74 ms te9-2.ccr02.mci01.atlas.cogentco.com [154.54.24.
118]
12 83 ms 78 ms 76 ms te7-2.mpd02.ord01.atlas.cogentco.com [154.54.25.
78]
13 89 ms 89 ms 88 ms te2-3.mpd01.yyz02.atlas.cogentco.com [154.54.7.1
7]
14 107 ms 108 ms 111 ms te9-8.mpd01.ymq02.atlas.cogentco.com [154.54.25.
26]
15 188 ms 179 ms 178 ms te2-2.ccr02.ams03.atlas.cogentco.com [154.54.0.7
3]
16 194 ms 197 ms 196 ms te2-7.ccr01.fra03.atlas.cogentco.com [130.117.1.
161]
17 193 ms 199 ms 201 ms te7-3.mpd01.fra03.atlas.cogentco.com [130.117.3.
202]
18 200 ms 205 ms 226 ms 149.6.141.59
19 198 ms 199 ms 199 ms ip-62-75-135-1.intergenia.de [62.75.135.1]
20 242 ms 201 ms 199 ms tigerwerk.de [85.25.120.51]
Trace complete.
My location:
USA
Ping for US server:
German Server :
.87.170.137]
.87.170.9]
.86.90.249]
68.86.85.206]
t [68.86.85.197]
8.86.85.181]
105]
73]
118]
78]
7]
26]
3]
161]
202]
Trace complete.
IGN:- Greendragon
IGC:- Holy Knight
IGKH:- Maniacs
IGT:- Quanato
IGC:- Holy Knight
IGKH:- Maniacs
IGT:- Quanato
[GM]Desire
- A3 Mania Gamemaster
Re: Server Shifting
Internet Service Provider : MTNL
Ass4ult
- Hell Yatake
Re: Server Shifting
netdemon
- Cullijpayhern
Re: Server Shifting
Does anyone know how to run ping from behind a corporate firewall??
rooney8
- Wimos
Re: Server Shifting
Ping- Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Admin>ping 85.25.120.51
Pinging 85.25.120.51 with 32 bytes of data:
Reply from 85.25.120.51: bytes=32 time=285ms TTL=46
Reply from 85.25.120.51: bytes=32 time=286ms TTL=46
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Minimum = 285ms, Maximum = 286ms, Average = 285ms
Tracert--
C:\Documents and Settings\Admin>tracert 85.25.120.51
1 1 ms <1 ms <1 ms 192.168.1.1
2 15 ms 13 ms 13 ms 59.93.64.1
3 31 ms 31 ms 29 ms 218.248.255.26
4 28 ms 27 ms 29 ms 59.162.0.218.static.vsnl.net.in [59.162.0.218]
5 558 ms 559 ms 565 ms 59.163.16.242.static.vsnl.net.in [59.163.16.242]
6 537 ms 537 ms 531 ms if-10-2.core1.LDN-London.as6453.net [195.219.48.
177]
7 549 ms 563 ms 559 ms if-9-2.mcore3.LDN-London.as6453.net [195.219.195
.17]
8 637 ms 555 ms 551 ms ge4-1-0-1000M.ar3.LON2.gblx.net [64.208.110.81]
9 577 ms 585 ms 579 ms ge2-1-10g.ar1.fra4.gblx.net [67.17.105.69]
10 284 ms 283 ms 283 ms tge-4-2-0-0a.cr2.fra.routeserver.net [208.51.239
.190]
11 283 ms 285 ms 283 ms ip-62-75-135-1.intergenia.de [62.75.135.1]
12 284 ms 285 ms 285 ms tigerwerk.de [85.25.120.51]
Trace complete.
BSNL broadband
Hyderabad,Andhra Pradesh, India
Tracert--
177]
.17]
.190]
Trace complete.
BSNL broadband
maxihiren
Re: Server Shifting
BTW Srry to disturb.. to post this post here..
but GMs my char got hacked...
ifu can do some thing pls reply me!!!
WinninG
HK
¥ M@x!Mu§ ¥ th3 Glað!@t0r
HK
Re: Server Shifting
Open a support ticket.maxihiren wrote:BTW Srry to disturb.. to post this post here..
ifu can do some thing pls reply me!!!![]()
The Shining Wizard
- Asshole
Re: Server Shifting
1. Ping:
2. Tracert
3. Location and City: Hyderabad, Andhra Pradesh, India.
4. Internet Connection: BSNL DataOne Broadband (256 kbps unlimited)
USA Server:
1. Ping:
2. Tracert
SNG Server works smooth for me. Only at times do I lag. But otherwise, it's very smooth, unlike the US server which always lags.
However, I don't like the looks of this. I seriously don't.
Code: Select all
Reply from 85.25.120.51: bytes=32 time=260ms TTL=53
Reply from 85.25.120.51: bytes=32 time=259ms TTL=53
Packets: Sent = 6, Received = 6, Lost = 0 (0% loss),
Minimum = 259ms, Maximum = 260ms, Average = 259msCode: Select all
1 13 ms 13 ms 14 ms 117.195.128.1
2 14 ms 13 ms 13 ms 218.248.164.134
3 29 ms 29 ms 29 ms 218.248.255.66
4 303 ms 304 ms 303 ms 125.16.156.25
5 293 ms 292 ms 293 ms 203.101.95.133
6 252 ms 251 ms 253 ms pal2-bharti-1.pal.seabone.net [213.144.181.85]
7 259 ms 258 ms 258 ms global-crossing-2-decix.fra.seabone.net [89.221.34.50]
8 277 ms 447 ms 417 ms te1-2-10G.ar1.FRA4.gblx.net [67.17.111.177]
9 254 ms 314 ms 255 ms tge-4-2-0-0a.cr2.fra.routeserver.net [208.51.239.190]
10 259 ms 258 ms 259 ms ip-62-75-135-1.intergenia.de [62.75.135.1]
11 260 ms 259 ms 260 ms tigerwerk.de [85.25.120.51]
Trace complete.3. Location and City: Hyderabad, Andhra Pradesh, India.
USA Server:
1. Ping:
Code: Select all
Pinging 69.64.47.153 with 32 bytes of data:
Reply from 69.64.47.153: bytes=32 time=280ms TTL=52
Ping statistics for 69.64.47.153:
Packets: Sent = 5, Received = 5, Lost = 0 (0% loss),
Minimum = 280ms, Maximum = 280ms, Average = 280ms
2. Tracert
Code: Select all
Tracing route to balder923.startdedicated.com [69.64.47.153]
1 13 ms 14 ms 13 ms 117.195.128.1
2 13 ms 13 ms 13 ms 218.248.164.134
3 29 ms 29 ms 30 ms 218.248.255.2
4 303 ms 303 ms 302 ms 125.16.156.25
5 285 ms 285 ms 285 ms 125.21.167.74
6 278 ms 278 ms 278 ms so-4-2-2.edge2.LosAngeles1.Level3.net [4.78.198.5]
7 283 ms 274 ms 285 ms vlan79.csw2.LosAngeles1.Level3.net [4.68.20.126]
8 274 ms 285 ms 275 ms ae-93-93.ebr3.LosAngeles1.Level3.net [4.69.137.45]
9 281 ms 285 ms 288 ms ae-2.ebr3.SanJose1.Level3.net [4.69.132.9]
10 284 ms 287 ms 288 ms ae-83-83.csw3.SanJose1.Level3.net [4.69.134.234]
11 287 ms 288 ms 288 ms ae-82-82.ebr2.SanJose1.Level3.net [4.69.134.217]
12 281 ms 288 ms 288 ms ae-3.ebr1.Denver1.Level3.net [4.69.132.58]
13 280 ms 280 ms 279 ms ae-4-4.car1.StLouis1.Level3.net [4.69.132.181]
14 279 ms 280 ms 279 ms ae-11-11.car2.StLouis1.Level3.net [4.69.132.186]
15 281 ms 282 ms 283 ms MESH-SOLUTI.car2.StLouis1.Level3.net [4.53.162.78]
16 357 ms 278 ms 278 ms 69.64.45.30
17 281 ms 280 ms 280 ms balder923.startdedicated.com [69.64.47.153]
Trace complete.
IGN: Soledad
IGG: BloodAngels
IGC: Mage
IGG: BloodAngels
IGC: Mage
AthenaIndia
Re: Server Shifting
Hi Sir ,
1. Ping =
Pings of Germany Server
Reply from 85.25.120.51: bytes=32 time=192ms TTL=51
Reply from 85.25.120.51: bytes=32 time=203ms TTL=51
Reply from 85.25.120.51: bytes=32 time=187ms TTL=51
Pinging 85.25.120.51 with 1000 bytes of data:
Reply from 85.25.120.51: bytes=1000 time=193ms TTL=51
Reply from 85.25.120.51: bytes=1000 time=191ms TTL=51
Reply from 85.25.120.51: bytes=1000 time=195ms TTL=51
2. Tracert =
1 15 ms 15 ms 15 ms 120.89.73.2
2 15 ms 15 ms 15 ms kan-gw.denbroadband.in [120.89.73.1]
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
13 203 ms 203 ms 187 ms tigerwerk.de [85.25.120.51]
Trace complete.
3. Your Location and City = India , Uttar Pradesh , Kanpur
4. Internet Connection that you are using. = DEN - IN Broadband
Pings of USA server =
Pinging 69.64.47.57 with 32 bytes of data:
Reply from 69.64.47.57: bytes=32 time=330ms TTL=113
Reply from 69.64.47.57: bytes=32 time=328ms TTL=113
IGN: AthenaIndia
IGC: Archer
1. Ping =
2. Tracert =
Trace complete.
IGN: AthenaIndia
IGC: Archer
