Stats.
- Location: Rubal's Castle (Although it aint created till date :P)
Re: Stats.
This is valid at a certain level only..............Once you take rb and your stats are reseted its not necessary that you keep stats according to these you can keep a fixed value of dex and attack and the rest in vita for example 1000 dex and 1500 attack and 500 stats in mana etc..........
Re: Stats.
u wudnt need mana a lot...
the basic stats u wud need to go for an archer wud be by its built!!
hp bar shud be at a minimum of 9k-10k at the later stages..
attack shud be 2000+
dex shud be around 1500+
this is at 12th rb according to what i expect wud be nice!
- Hell Yatake
Re: Stats.
For 12th RB you get only 3600 points+165 x 6 = 3600 + 990 = 4590.rockstar8 wrote:u wudnt need mana a lot...
So i dont think an archer can have 9k-10k hp bar at that RB.
If attack n dex is 2k n 1.5k respectively.
Re: Stats.
i was just saying...
n btw u'll be having 5k bar without blood itself..
by default so adding up the 990 points u'll be gettin around 3k bar there...
8k is possible!!
8k is possible!!
- Torturer
Re: Stats.
guys there is no use of having high hp bar for archers for pvp. More the hp bar more the damage u will get on the archer.Stats according to rb 12 165 shud be:
Strength (NOt attack power) == 2k as this can vary. This will do 15k max on bosses wid grahsat lvl 10. Can do more wid lvl 15.
Defence(Not dexterity)==1.6k
Hp bar==6.5-8k nywere in between wil do nice.
no need to add nything to mana
Learn correct passives
- Yahgon
Re: Stats.
u mad or wat? with 2k in STR & lvl 10 grahsat u wil do 15k damage on bosses?crista wrote:guys there is no use of having high hp bar for archers for pvp. More the hp bar more the damage u will get on the archer.Stats according to rb 12 165 shud be:
u can hardly do 12-12.5k damage in that stat
IGN - Krait
IGC - Archer
IGL - RB 12, 165
]3acK W!th a ]3la$t
IGC - Archer
IGL - RB 12, 165
]3acK W!th a ]3la$t
Re: Stats.
Krait..ull do 15k Damage..crista is right
Bout the stats...i cant disclose Archer stats .... coz its all the hardwrk of one of my frnds..n he wuldnt like it if i did so.. !
but if ne1 wants to ask me bout mage stats n all..ill be too happy to advice them on it.. !!
- Yahgon
Re: Stats.
u can never do 15k damage even with KW with that stat & lvl 10 grahsat...
IGN - Krait
IGC - Archer
IGL - RB 12, 165
]3acK W!th a ]3la$t
IGC - Archer
IGL - RB 12, 165
]3acK W!th a ]3la$t
Re: Stats.
Oops...Correction : i didnt read crista's post correctly..i thought its bout lvl 15 ghrasat.. !
I agree to krait..u can never do 15k damage....ull do some 13k damg..with lvl 10 ghrasat !!
- CA_Harsh
- Hautz
Re: Stats.
Stats doesn't matter much as compared wid eles
As i play an archer, i think the stats shud be
==>1000-1200 points in attk.. i knw its a bit shocking..bt thts true....coz as all are A5 (same lvl) ele's difference in both... i.e=attk and defence shud be considered...i mean if u put 1k or 2k points in attk..it wont matter much....(xcept bossing or W quest) bt in tht case u jst hve to hit sm more arrows which is nt a big deal...!!!
Coming to defence ,
==> As far as i knw , defence works against players at a certain extent only.... i.e = 1.5-1.6k....bt as u put less points in attk , defence shud be higher...as i said earlier ele defence matters more then basic defence...bt basic defence will help u in bossing as well as in W quests....so raise ur defence upto 2-2.2k.....!!!
==>And the rest shud be put in blood...as it helps u in arena and war too (especially when u fly non-dex
-Rest ur wish....as they are ur chars... ;)
Enjoy gaming
Coming to defence ,
Enjoy gaming
Crazyarcher
Alfaqforever
Maleficient
Be-like-water
Alfaqforever
Maleficient
Be-like-water
Re: Stats.
Def 2-2.2k ..lol ..dats askin too much .. i hope u know 1 def increases wid 2 pts
- Razbojnik
Re: Stats.
maxi thats not too much for player wid bugged stats, haven't u heard bout bugged stats at rb 8 ??
IGN:Lusttt
IGC:Archer
IGT: Quanato
IGC:Archer
IGT: Quanato
- Yahgon
Re: Stats.
wats that subho? pm me ingame abt it
anyways Stats are of 3 types.
1) For Hunting.
2) For Pvp-Arena
3) For war.
In hunting if u got a decent mercy then pump ur attack and keep bar nominal.
In PvP-Arena u have to waste billions on lores till u come up with the stat you are comfortable with.
For only war purpose u need 2 be a tanker coz attack gets stabilised in certain range against players as well as defence.
So its totally upto the player on which build u want to go for.
1) For Hunting.
2) For Pvp-Arena
3) For war.
IGN - Krait
IGC - Archer
IGL - RB 12, 165
]3acK W!th a ]3la$t
IGC - Archer
IGL - RB 12, 165
]3acK W!th a ]3la$t
- CA_Harsh
- Hautz
Re: Stats.
@max sry..my mistake..2k is much higher...it shud be around 1.6-1.7k...
@suvo...
I knw u are jst giving an excuse coz u cnt defeat me! As far as bugs are concerned... Chk ma topic in general section..! GET LOST NW LOOSER!
@suvo...
Crazyarcher
Alfaqforever
Maleficient
Be-like-water
Alfaqforever
Maleficient
Be-like-water
