[Guide] Increase Melee Rate
This is a Patch for Windows Registry inorder to Tweak the TCP/IP Settings to Boost Performance in ALL MMORPG's.
This patch will turn off the TCP ACK (Acknowledgment) Frequency. This is ensure that the server sends the data immediately. For more information on this Setting Please check the Microsoft Knowledge Based:
http://support.microsoft.com/kb/328890
Instructions:
Download the File.
Open it and Press Yes.
It will be showing the changes made to all the network adapters.
Keep pressing Okay, Until you are asked to Make a Reboot.
Save all your Programs and Reboot your PC.
Login Ingame and notice the change.
Your Melee speed will better because if the Registry patch is not there, the Server waits for 200milliseconds before sending another packet of data, hence the 200ms will slow down the Hit speed. If you Apply this patch, the Server will send data continuously due to which the Performance will increase.
Re: [Guide] Increase Melee Rate
Using this Setting MAY change the speed for downloads. It is adviced that you use this patch for Gaming Purpose only.
Open that EXE file. Click on Patch.
Go to the Desktop. You will find a REG file called TcpAck.reg. Double click on that and add the information to the registry.
Restart your system and notice the change.
