You can find the next text in several places
"20x Normal XP. 5x Quest XP. 5x Drop Rates."
And those are not the real rates, so my suggestion is to change them for the real ones, the ones that we have must of the time.
rofl yea we are fine with this exp only thanxRabellu wrote:They need not correct anything because the ingame exp bar is smthing different wat u ppl are thinking.
The Ingame exp bar calculations goes as follows:
-> 1.0 = Normal exp (like in a3india)
-> 2.0 =10x of Normal exp
-> 3.0 =20x of Normal exp
-> 4.0 =30x of Normal exp
Now think if they set 20.0 for ingame bar then it will be like 190x of normal exp which mean hunt in GP for 2-3 hours nd u will be 165lvl.
Hope u got it now nd wnt confuse ingame bar with the exp mentioned at website.
Enjoy
nice info !!!!tat explains the xp but drop rate ?5xRabellu wrote:They need not correct anything because the ingame exp bar is smthing different wat u ppl are thinking.
Enjoy
Same applies for drop rate also re, see above post. Same as XP .vitalstrike wrote:
