My ISP DOES NOT SUPPORT A3 mania
vivalagloriaforum
Post by vivalagloriaforum »
CharName: Chique
Is it an Issue or a Question to GM?: Issue
Have you raised a support ticket at the main website?: No
Issue or Question Type: Account Related Issue or Query
Description and Message
Dear GM..
My ISP ( Beamcable-IN) supposedly doesnot support a3 mania..
When i try to ping acp.a3mania.com i keep getting RTOs and the Server status section in the homepage also doesnot show up.. Moreover, the ACP section also doesnot open.
After i called my ISP technical service, he told me that if there's a virus in the site i wont be able to ping the site due to security issues.
Kindly help..
Forum Robot
Automated
Automated
Post by Forum Robot »
Thank you for posting your request. Please wait for GMs to look into this matter. They will reply to you as soon as possible.
This is an automated reply
Please also make sure that you have logged a support request in the A3 Mania main website for faster resolutions. Also please read the announcements section for regular updates regarding server maintenance and updates.
Click here to Know how to log a support request in A3 Mania Website.
Thanks,
Re: My ISP DOES NOT SUPPORT A3 mania
Maybe your firewall is blocking. It should work fine.
Also there might be some DNS issue.
Try the following:
Start -> RUN
Type "cmd" and press enter
In the black box, type "ipconfig /flushdns"
After doing that, close the Black box and then try to connect.
vivalagloriaforum
i did whatever u asked me to.. still no luck..
also my friend with the same ISP is not able to connect..
im not able to ping acp.a3mania.com !
Any other solution?
Does the game Run? Have you updated the client and are you able to connect?
vivalagloriaforum
The game got updated. But when i type my ID and password in the login screen .. it just freezes and gets stuck.
Check the Ping window. It should show something like "Pinging [124 bla bla]"
Tell me the IP in the Square bracket that you are able to see.
vivalagloriaforum
124.123.65.8
Disable your Firewall for few minutes. I will try to check connectivity to your IP from the Server end.
vivalagloriaforum
I disabled it. try now
Yes. Your ISP is blocking A3 Mania. I will ask Scar to speak to your ISP regarding this issue tomorrow.
You may enable the firewall now.
vivalagloriaforum
Alright. Thanks for the help.
Does it work now?
vivalagloriaforum
Not yet GM.. I'm getting impatient now X_X
vivalagloriaforum
Anyway that i can do a live chat with you and sort it out?
Locked
