Request to A3 Mania GMs: Need Server IP to Check Ping/Route
Knm
Post by Knm »
Hi GMs,
Could you please provide the A3 Mania India server IP address (or any method to directly ping/tracert it)? I want to run a ping and traceroute test from my end to check the route and latency.
I'm currently on Airtel Xstream Fiber and getting high ping than usual, I'd like to explore if it's possible to optimize the route and reduce ping.
Once I have the IP, I plan to contact Airtel support and ask if they can improve the routing path for better performance. Any help or info from your side would be appreciated!
Re: Request to A3 Mania GMs: Need Server IP to Check Ping/Route
Only the login servers IPs are fixed and the actual game servers have IP rotation for load balancing based on the server you choose during login. It's meaningless to check the pings for the login servers since they don't reflect the actual ping that you get ingame.
With that being said, Airtel has been a trouble spot for us for quite a long time with no proper resolution. They just don't care.
Knm
Post by Knm »
I understand, thanks for clarifying about the rotating game server IPs.
What I was actually looking for is a way to test ping from different locations and ISPs — for example, from my friends’ homes — so I can figure out which ISP performs best for A3 Mania in my region.
I won’t be able to download and install the full A3 game client on their PCs/laptops just to check ping. So if there’s any tool, method, or lightweight test that can measure actual in-game latency without installing the whole client, please let me know.
You can use the IP address in this post to get approximate pings.
viewtopic.php?p=46275#p46275
Knm
Post by Knm »
Thank you.
